The F1.2 is just a half stop faster. ( hardly noticaebale unless they are Directly compared split screen) But the Canon FD 55mm s.s.c. F1.2 is a much sharper lens than the 50mm s.s.c. F1.4.
thekyleman71 said:im having a really hard time understanding what type of lens i need to get to attach to a letus35a adapter. i am going to buy a 72mm threaded letus35a so i can attach it right on to my dvx, and then it is my understanding that i will need to get another lens. so, in other words: DVX --> ADAPTER --> LENS is this right? i'm really confused.
snodart said:I'm using a Canon FD f/2.8 28mm and an FD f/1.4 50mm. f/2.8 is a little slow for the 28mm, but can still produce nice images.
Keep in mind that "fast" and "slow" just refers to the lowest f/stop setting. So a lens with a minimum f/stop setting of f/2.8 is considered "slower" than a lens with a minimum f/stop setting of f/2. It doesn't mean much more that that.
If you do end up going with Canon FD, there is a little "trick" you will need to do with some FD lenses to engage the f/stop lock lever.
The lever above is normally engaged when attached to a camera. I just cut a small piece from some from brass flat stock (hobby stores), cut it to length, slid the lever over, and inserted the brass piece. Easy fix and works fine. I had forgotten it was even there until you mentioned FD lenses.
Good luck
snodart said:The aperture will not function unless that lever is slide over and held in place. The goal with using the small piece to keep the lever in the engaged position is so that the aperture will function normally. This way, when you adjust the f/stop, the aperture will react accordingly.
You want to be able to adjust the f/stop of the lens as it is an important tool in setting up your images. It will allow you to alter the DOF and fine tune your exposure. Also, with most lenses... wide open is not the "sweet spot" so the images may not be as sharp as is possible with a given lens.
wjm said:Hey J.G. It's Matt from the DVXUser.com meeting in Denver a couple weeks back.
Here's what I understand:
Try to keep BOTH lenses at their own sweet spot - that is, a stop or two closed down from full open. For the DVX, this is about F4.0, and for your SLR lens, that varies. I have an F1.2 50mm, and I try to keep it at F2 to F2.8.
Hope that helps. Take it easy.
