Barry_Green said:So I went with the Vocas MB-250 (which is also sold by Century Optics, I think they call it something like the Century 4x4 Wide Angle MatteBox Mark II), and I'm content. The Vocas may not be perfect, but I do think it's a better match for the HVX than the Chrosziel is, and it's a bit less expensive too. Especially when used with the Century lenses. Vocas uses its own filter holders that aren't compatible with the Chrosziel or CAVision, which is a point against it.
Barry_Green said:Also, my Vocas has the rails with the goofy flip-out shoulder thing. I puzzled over that one, as it seems to present itself as a ghetto "shoulder mount", but it's not at all, if you tried to put that extended portion over your shoulder you'd accomplish nothing more than to make yourself look goofy. But what it does do is let you jam the shoulder thing into your shoulder, and that helps stability enormously. If you just butt the thing up against your shoulder you can handhold so much more efficiently; it removes your wrist from the equation entirely (instead of three axes of rotation around your wrist, you now have a solid non-moving surface). So it looks a little silly, but I think it's darn handy for handheld work. It's not comfortable, of course, but it is stable. I still prefer using the Steadi-Stick to stabilize because it takes the weight off your back and arm entirely, but if you don't have something like that, the flip-out shoulder brace thing does work surprisingly well. It's not a "shoulder mount", it's a brace you brace the camera against, and in that context it does what it should and makes handheld shots much more stable.
