Just lost my filmmaking virginity yesterday with first short film!
Sorry to waste your time on this beginner stuff.
Got 25 min of 24p adv letterbox footage (some 100 pauses in it, never took the tape out) with my dvx100p.
Tc mode is set to df, tcg to rec run, first rec tc to regen, tc preset to (----).
Got FCP 5.1.
I went through capture chapter in the manual. All I want to do is ‘capture now’ and chop it up in fcp.
In capture settings, device control is firewire ntsc, capture dv ntsc 48 khz. I also tried the 48 khz advanced pulldown 2332. in both cases, after hitting play and ‘now’, it captured at 30fps.
when you play it back in the final cut, the video is lagging behind sound. Also, there is a lot of aliasing. Is that because of the 30fps?
Here’s the strange thing. When I go back to beginning of tape, and capture, say a minute or two with the pulldown capture (the footage contains multiple pauses and camera being off, just like rest of the 25 minutes, not one continuous take) – it saves in 24p, no video lag, and only a little aliasing (why is there aliasing anyway?)
Why can it capture a bit in 24p but not the whole 25 minutes?
I read the stickie about capturing in 30 fps…can I take the aliased, lag-video 25 min clip I captured and do the pulldown? How would that be done? Manual says quite a bit about pulldown in regard to outputting to video, but nothing I came across about converting captured clips.
Thank you so much!
vw
Got FCP 5.1.
Thank you so much!
vw
