wabbit said:Good advice. I would add that "creeping" into frame is not as effecient as a "boom check". The boom op calls out, "Boom Check!" and drops the boom into frame while the camera op calls out, "In" and then the boom op slowly backs the boom out until the camera op says, "Out." That is your frame line. This usually takes less the 5 seconds. After awhile your boom op shouldl learn where the frame line is for most shots without a boom check.
Cheers
