Widescreen Monitor for HVX
Is this a good one for the HVX?
The V-R70P-SD is the successor to the V-R70-SDI. Significant improvements over the previous model include our Completely Digital TFT-MegapixelT high resolution LCD screen with 1.2 million pixels, V-Mount battery adapter, 4 pin XLR power jack, and optical grade polycarbonate screen protection. Analog signals are digitized using an advanced 10 bit process with 4x over sampling and adaptive 5 line comb filter plus exacting color space conversion. Video is scaled to fit on screen in the highest resolution using a state of the art LSI that incorporates 4x4 pixel interpolation with precision Gamma correction to product the best images available. • Durable metal enclosure
• "V" Mount battery adapter included
• Runs 4 to 6 hours on optional 50WH battery
• High Resolution 7-inch wide screen 800x480 Dots with 1.2 million pixels
• Optical grade polycarbonate screen cover with Antireflective/Antiglare coating
• 100% digital processing
• Analog signals converted to 10 bit digital
• High resolution scaling of all images
• Wide viewing radius - 130° horizontal and 120° vertical provides superior visibility when
the viewer is not directly in front of the screen
• 380 candelas per square meter (cd/m2) luminance produces enhanced image quality
in varying light and viewing conditions
• 400:1 ratio of contrast between black and white luminance values with response
rates less than 30 ms results in excellent quality for moving images
• 4:3 and 16:9 screen aspect ratios
• Automatic NTSC/PAL format detection
• Standard inputs:
• SDI (Smpte-259M) with reshaped & reclocked output
• Y/C (S-Video) with loop output
• Composite Video PAL/NTSC with loop output
• 4 Pin XLR D.C. power jack
• Easy to see three color tally indicators
• Built in Color Bars
• Blue Screen for color adjustment
• Adjustment Settings Memory
• Includes ¼-20 mounting plate that can be attached to any edge of the enclosure
(additional mounting plates available)
• Includes universal voltage Class-2 power supply
• Fits into Tektronix ® WFM7F05/1700F05 rack adapter
• Optional rack mount kit
SPECIFICATIONS
Number of Screens​
1
Display (Viewing Area)​
7" (6.14"H × 3.27"V) (156.0mm x 83.28mm)
Resolution ( RGB Dots)​
800H x RGB x 480V (1.2 million pixels)
Viewing Angles​
130° H x 120° V
Dot Pitch​
0.065 mm (W) x 0.175 (H)
Contrast Ratio​
400:1
Pixel Response​
<30ms
Brightness​
380 cd/m²
System​
NTSC/PAL auto recognition for standard definition signals (SMPTE RS-170A)
APPLICATIONS​
• Video assist
• Talent Monitor
• Signal confidence monitor
• Security and survielance
Yes it is a good one... they need to calibrate it for the hvx from factory though or you have to send it in to marshall. be sure to search the forums before you post - this topic has been discussed a lot.
Never had my Marshall V-R70P-HDA sent off and calibrated and it works absolutely fine.
Whats all that about? I have a PAL HVX
If you purchase the marshall monitor from Nebtek with the panny battery conversion do you still need to send it in to have it calibrated?
So far this year we have shipped several Marshall V-R70PHDA units modified with Panasonic battery adapters and had no complaints. However, we have had 2 units sent back to us for the Panasonic upgrade in the past month (we have to send the unit back to Marshall for the software upgrade). It appears that some of the units function properly when used in conjunction with the HVX-200 and some do not. NEBTEK is in the process of ordering Panasonic specific V-R70PHDA units for our customers that do use the HVX-200, but as yet none of those units have arrived.
All the best,
Rob
NEBTEK.COM
