puredrifting
Major Contributor
Hi all:
Glimmer - $2,500.00 is a good, realistic base to work from for a beginning lighting kit. One other point that is being overlooked in this thread is grip equipment. Grip equipment, in the level we are discussing here are basically tools to shape and modify the light. IMHO, besides lights you need a few light stands, a few C-stands, some sandbags, a reflector, dimmers, gels, diffusion, cinefoil, grip clips, C-47s, etc.
You MUST have the proper tools to control the light or you will be frustrated and unable to create beautiful pictures without the right tools. I personally agree with Taubkin, buying something like the Chimera kit I recommended is a wise choice. Is it cheap? No. Will it last you well into your career as a videographer/filmmaker/DP/etc.? Yes, definitely. I am still using two small Chimeras that I bought 6 years ago.
Personally, I would discourage you from buying a kit beyond the kit that I recommended, mainly because your needs may be different than our needs. BUT, you will need grip gear to make your lights work. The key setup that I recommended is a good start. The Lowel ProLight that GageFX recommends is a good way to go as a rim/hair light and does cost about half the price of the Arri 150 fresnel. I own three of the Arri 150s and two of the Lowel ProLights. The Arris are better because they are a true fresnel but as a hairlight, you don't really need a fresnel. For tabletop, yes, you need a fresnel but for shooting people as a rim/hairlight, the Lowel is fine.
Bosindy, your question is not dumb. The Chimera kit light is a base that can accept different size lamps, most fixtures can. The Lowel ProLight can take several voltages/wattages as well but the max is 250 watt.
China Balls are okay but be careful with tungsten, they can torch rather easily. Also, they are "sloppy" in the sense of they spread a big blob of soft light everywhere. If that's what you want to accomplish, they are fine, they are also good for walking shots but personally, I like to control the light more than that. Chimera makes a fireproof china ball/pancake that has barndoors of sorts, these are better but cost a ton more than China Balls do.
Cheap fluoros, I am experimenting with them at the moment. They are not bad but you must make sure that you buy hum-free, flicker free models. The CRI (color resolution index) is rather bad, meaning they can be tricky to try to obtain accurate colors. I am working on a homemade Kino-Flo that I am creating with six GE undercounter instruments. It looks nice, throws a nice light and seems to be around 3,050 K as far as color temp. Not sure how they will integrate with tungsten yet, still running tests.
All the best,
Dan
All the best,
Dan
