I've searched these boards multiple times, and I can't find the best answer to my question. Pls forgive the fact that this is redundant, but I do appreciate any input.
I shot 10 hours of doc footage in f5 24p normal. I then started batching the footage in FCP Studio with the wrong settings... I chose 23.98...
Now, I've batched LOGGED 9 hours... but have not yet captured that footage. However I HAVE captured 1 hour of footage... again, this is f5 24pn footage captured with a 23.98 setting (and it looks mildly jaggedy and stroby).
So the question is how to best rectify this situation? I have hundreds of batch log in-and-out points that I do NOT want to loose, however I assume that since I haven't actually captured the footage, it shouldn't be a big deal, right? So should I:
1. Export the batch LIST as is, and then import it back into a new project at a proper 29.98 setting and THEN go ahead and capture everything? If so, then I assume I will also need to recapture the hour of footage I have currently captured incorrectly, right?
or
2. Just change the sequence and capture preset settings (ie, via Audio/Video settings) in the project to DV NTSC 48 kHz and then all I have to do is recapture the 1 hour of footage?
or
3. capture everything at 23.98 and reverse telecine it all after? in which case I'd have all 24p footage on a 24p timeline... which may be beneficial if I choose to do a 24p DVD... but will I loose image quality this way (I already know I will loose time...)?
Final output will be DVD, miniDV, and web streaming broadcast.
Thoughts? Thanks for ANY input.
or
or
