Smooth Audio and Dialogue?!
ki8
How do you make your Dialogues not jump form one dialogue to the other...since there are difference sounds on each take how do you make the surroundings as well the dialogue flow so well, without cuts taht seem HORRIBLE...how do i do it...thanks
first you start by getting as good production sound as possible. second, you get a really good dialogue editor. third, you cut good bg's. fourth, you get a really really good re-recording mixer to mix it for you.
-Dave
And you must have clean dialogue with as little background sounds as possible, and separate, continuous backround audio. Basically dialogue & effects sounds are mixed on top of this ambience track.
Make a 1 sec crossfade on all soundtrack edit points, makes the audio so much smoother.
If the problem is that different shots have wildly different background noises (and the noise can't be eliminated during production or filtered out in post), you may want to record two separate room tones.
For example: Shot A and B are both medium shots of two people facing one another in a conversation (ie. shot and reverse-shot). Let's say there's a lawnmower in the background of shot A, and that the lawnmower is well off-axis on the mic during shot B. Record separate room tones for shot A and B during production. During post-production add shot A's room tone to shot B, and vice versa (on separate RT tracks with the neccessary cross-fades, of course). You'll increase the overall noise floor, but this will eliminate the room tone disparity across cuts. A skillful re-recording mixer will mix it in such a way that the overall noise floor is minimized. Its a bit of a compromise, but its one way to deal with unevenly noisey production sound.
1 second is a little too general. Sometimes that's way to much, or sometimes it's not enough. When I'm cross fading BG's from scene to scene, it's usually just 2 or 3 frames of a crossfade. If I'm trying to cover up crap in the production track, well that's a different story, and pretty much anything goes as long as it sounds good.
Interesting enough Ki8, your question is pretty much the rudimentary quest that drives the whole sound dept. From beginning to end that is what we are trying to achieve and it cannot be accomplished in only part of the production process.
That being said, the above info is the best that can be offered in such a limited communication style as this forum. Read up on post production sound books to learn the finer steps of putting it all together. But if you did not get good, consistent sound on set you are more then likely screwed in post production. ADR will become a term you learn to dread.
Good luck
