Hi and thanks to David, Barry, and all of you for gracious help on these forums.
I have 4 questions - one about workflow, two about Vegas settings, and one about Sony ACID.
1. Workflow:
I've shot over 20 hours for a Hobo Documentary in 24padvanced, using Panasonics' 16x9 conversion Lens. In the past I've first rendered the captured files into smaller clips, and then edited the movie from that. Here is my question:
Following the above method, should I first render the smaller clips into uncompressed AVI, or go ahead and use Vegas' 24p-widescreen 2-3-3-2 render setting? Should I be concerned about quality loss? - talk to me like I'm new.
2. Vegas Settings - "Maintain Aspect Ratio"
Since I shot in 4:3 with a conversion lens, I can get the appropriate look by turning off the "maintain aspect ratio" switch on the clips I'm editing. Is there any "macro" way to do this in advance? Maybe a script?
3. Vegas Settings - "Audio Bitrate"
What is the proper audio bitrate settings in Vegas for the DVX100a? I currently have it set to 16 by 44100, which seems to be default. Should I up either rate, or will I merely be adding file size and processing time by doing so?
4. Sony ACID Pro 6 - "Video Edit"
I've been playing around a bit on a different project with Sony ACID music looping software, which includes a minimal track editor. Just wondering if anyone had experience with this, as I'm considering doing my primary editing for a small film in ACID.
Thanks again,
Andrew J. Holden
http://cyberpunkfilm.com
1. Workflow:
Thanks again,
Andrew J. Holden
