You have to record a script using the Action tab. You can replay the same "action" to any file.Slimothy said:How do you then apply the same effect to many pictures in Photoshop?
I'm not sure I understand, but I'll mess w/ it and see what I come up with.SafetyO said:You have to record a script using the Action tab. You can replay the same "action" to any file.
Under the Help Menu: An action is a series of commands that you play back on a single file or a batch of files.
It took a little bit of experimenting to figure it out exactly, but it saved a whole lot of time when I used it to resize and apply a filter to about 300 photos.
scharky said:Yes, unfortunatly, for some reason Vegas does not support exporting individual frames if you are using a 23.9 timeline. What I do is simply change the properties to 29.97 timeline with fields set to none, and export the frames like that. I then change the properties back to 23.97 before importing the footage back, it will then apply the appropriate pulldown to your footage to match the timeline. I'm not sure why it is like this, but it is, but this minor workaround seems to work fine. Let me know David if you know something more about this.
