Ralph nixon
I'm relatively new to electronic editing so please excuse my novice question but I was wondering several things:
1) How much memory does rendering take up on the harddrive? Does adding filters also take up memory?
2) Is an external hard-drive like the hard-drive on your computer where you have to make sure that you keep ten to twenty percent free so everything operates okay. Or with an external hard-drive can you use it doen to almost it's last gig.
Case in point I'm working on a 44 minute piece that i carved out of seventeen hours of raw material. I started with a 250gig g-drive that now only has 63 gigs left on it. Is that a safe amount to work with or am I going to find myself in trouble when I add more filters and do some colour correcting etc.?
3) Also I'm thinking of adding a whole layer of superimposed images under the entire piece. Will I have enough memory and render space to do this? If not what would be the solution?
Thanks.
Thanks.
