Official Filter - Polarizer - UV - All Filters F.A.Q
SurJones
I know I should get one, just have not had the time till now to research, which one is the best, and are there any differences to why it is the best..???? thanks guys
Also please post a link to filter.
Okay so I called B&H and they Said that we should be using a High Definition UV Filter.
Format HD UV fitler w/o haze $139.95 , A week to get in. BH Part # FOCUVHD82
I don't know the difference in quality off-hand but if you can't afford the pricier glass, then buy a cheap one right away. Even just to protect your lens. I think they can be had for $15. The Tiffen filter I got was $40 or $60. can't remember.
Here is what the features say.
Hi Def filters
Hi Def filters do not experience color shift - Specifically designed for use with High Definition filming
Optically consistant from filter to filter
Formatt filters use the finest materials together with state of the art production techniques; This has resulted in a standard of optical perfection unmatched anywhere else
All Formatt filters are manufactured using Water White Schott optical glass that is precision polished and ground to ensure absolute optical flatness and optimum performance
Absorbing Cell Technology
The secret to Formatt's consistency in filter design lies in its unique "Absorbing Cell Technology" (A.C.T.); This unique process allows color correct dyes to be applied to optically pure, wafer thin absorbing cells and offers a controllability that ensures the smoothest grad lines and consistent color across the whole filter surface.
This process is revolutionary compared with conventional filter dying techniques by eliminating the need to directly coat the glass surface itself; The repeatable performance gained through A.C.T. ensures that at any time you have to swap like filters for like filters mid shoot you can do so with confidence with no discernable differences in color or density.
Each filter is guaranteed flatness to a maximum 2-wave value and comes with an individual reading from a laser interferometer; Every filter is carefully verified with a densitometer and spectrophotometer to ensure consistent and accurate transmission, before leaving the factory - the result is an absolute purity of image that eliminates any unwanted colorcast caused by conventional greenish soda-lime glass.
Ultraviolet filters
If desired they can be left on the lens at all times for protection
Haze filters provide additional benefits of correction for Ultraviolet(UV) light which can register on film and videotape as a bluish cast and can obscure distant details
Ultraviolet filters allow you to correct for the UV effect to varying degrees
you are reading it wrong, it corrects uv light which can register as bluish cast on video tape if you don't have the filter
Nah, If you look at the picture, see the palm trees, you loose detail. Also we are not shooting tape, I would say 95% of the people who have a HVX has a P2, so should not be an issue right?
Yeah, I wondered about those simulated images for the haze filters. Do they really remove detailt that much?
LOL, I can't force you to read this statement correctly, in that it indicates you will gain detail and elimitate bluish cast with the filter on, but I would consider since the statement is used to sell the lens, I doubt it would highlight a negative in this way. In fact it uses the word "benefit" in the statement. Secondly, your pic says clearly it is a simulation so I would not go by that.
if I am mis- attributing your statement as to blur to that quote, my apologies, long day. other than that, i have not noticed any neg effects of the filter, but I am sure there are folks who have used it in more conditions than me, that can speak to possible blur.
If you look at the picture, it's the same FRAME. Same wave breaking points etc.
This looks to be a mock-up, how would you get the same wave breaks with time to change the filter???
If it's two camera's, how can we be sure fucus is identical?
Just wanted to point out how important "simulation" is. :)
I'm not saying you don't lose definition, but not in the previous lenses I've owned.
hehe ya, I know it is a simulation, but still simulation they are good are simulating what you will see.... Now on to matters, if you shoot film, or tape than the filter with haze will benefit you elimanating the bluish cast. But again being 95% of HVX owners haev P2, we should not need to worry about elimanating an issue that tape and film have...Right???
The haze issue has to do with landscape photography. If you you are shooting something far away there is a build up of ultraviolet light with all that distance. I've never noticed it particularely in video but its probably there. P2 would have nothing to do with it, its just how sensitive the chip is to UV haze.
Most people just use UV filters the same as they would use clear, to protect the lens. It probably does help with UV though I've never noticed the diff.
One last note on the simulation above, after a little research they use the same exact photo landscape for different brands including the clear UV lenses. It is not even a B+W simulation or haze specific.
I just ordered our Polarizer and clear FORMAT filters from B&H.
FORMAT is the best choice. IMHO.
So many things to buy when changing cameras!:(
Still glad I got the HVX though!!!
