Black borders on all four sides... why? (examples included)
Tobus
I film with a DVX-100B wide-aspect, and export with premiere at Pixel Aspect Ratio: D1/DV NTSC (0.9), because that's what it says the Aspect Ratio for my clip is (I didn't realize that at first, hence... the following video).
http://www.kkbbcasting.com/casting/?vidId=29907
Whenever I try to put a title screen on the video, the same effect happens. It looks fine in Premiere's preview window, but when I export it, it shrinks the video, putting black borders on all 4 sides, only for the duration where the title shows up.
I went to the properties of the Title screen and saw the Pixel Aspect ratio for it was 1.2, but it wouldn't let me change it. How can I?
The same border problem happens when I have video in two layers overlapping (so I just.. don't do that anymore...) and also when I apply reverse speed to any segment. That segment shows up in the exported clip with black borders on all sides instead of just top and bottom.
I'm pretty new and clueless, I've been winging it so far without title screens or video transitions.
Here's the video I mentioned earlier exported at the correct Aspect Ratio. Much better.. but too late for the contest. Hehe.
http://www.youtube.com/watch?v=RK7QF24_WDE
Here's another one. I used a title screen in this one, but only at the beginning. The title screen isn't adjacent to the video, and I couldn't use Crossfade because it was shrinking the final video. But it came out alright. (Warning: F word is present, said in a Duke Nukem voice)
http://www.youtube.com/watch?v=a5gp6SGWhWY
Is it the size that the player is set at? say you have a small video but the player thats embedded is set to big...is there going to be black surrounding it?
Your player is set at W-480 and H-376. the ratio is roughly 2.
A 4:3 letterboxed video will be at 1.5.
If i am correct...and i rarely am...change the width of your player.
Title screens are being programmed in Premiere as having a different aspect ratio as the video footage. The example video with the black border was exported with the same incorrect aspect ratio, but I can't figure out why video transitions cause the same effect, or how to correct it or the problem with title screens.
Maybe it's because I use 1.5? No idea.
