Any way to mux aud/vid for Mpeg2 from FCP or Compressor?
Ryan Hawk
Is there any way to export HD video as mpeg2 files from FCP or Compressor so that audio and video are on the SAME file (rather than the two separate files (aif and m2v) Compressor makes)?
I found the program Bitvice helper only works on SD clips when muxing the two files.
Anyone else find a way to do this?
Any help would be appreciated!
I've never exported MPEG files as one before, why do you need to do so?
EDIT: Did a Google search and found this app, click here, which will combine the two files together.
Also, you can export using QT conversion and this should output one file, but I've never tried it before.
It's the best quality format for running on some plasma displays the client has. But it's hooked into a system that needs to play them on demand.
Thanks for the link. I tried using it, but it seems to only DE-mux things as opposed to putting them back together again, unfortunately.
Thanks again.
Thanks again.
Well, try Export-->Using Quicktime Conversion, that should work.
