Footage is surprisingly smooth.
I'l post details later if anybody is interested...
EDIT BELOW
Added some sample footage.
Obviously, I need WAY more practice, but it's a start. I knew from reading on this forum and from trying a few other DIY stablizers that practice makes it work more than the unit itself. Gotta get that "Groucho Marx" walk down.
I ordered a Bogen quick release plate assembly which will be here Friday and then I will post more footage. I am also going to add a rubber gasket between the washers to better lock down the handles and prevent unwanted rotation.
BTW the Bogen Quick Release is beautiful - simple, strong, smart. Highly recommended.
Hose Handles: Serial # 077855825355 - $6.93 USD each at Home Depot
Aluminum Bar: Custom, found at local parts place. Home Depot offers some, but they are not "L" shaped as mine is. Not sure if it makes much of a difference - just make sure the bar is wide enough on top to accomodate the 1/2 holes drilled for each handle. Depends on the handles you use, and the way they attach to the bar.
Various washers and fittings. To attach the Bogen QuickRelease plate, I just used one of the 1/4" attachment screws that came with the plate. Works like a charm.
Hope this helps everybody. Now I have to go practice some more.
EDIT BELOW
