turing
hi all,
I'm about to get a focus - having used a couple cartoni packages (but not the focus) I was extremely impressed with the heads but not the sticks.
The head: http://www.bhphotovideo.com/bnh/con...s&Q=&sku=423406&is=REG&addedTroughType=search
The sticks I am considering:
http://www.bhphotovideo.com/bnh/con...s&Q=&sku=422068&is=REG&addedTroughType=search
(note that the picture is sort of innacurate - you have to order the sticks, feet and spreader separately - so $899 quickly becomes $1500)
http://www.bhphotovideo.com/bnh/con...s&Q=&sku=422064&is=REG&addedTroughType=search
are even nicer, but then I'd be in another $500, and the weight difference is very small (1lb).
The other option from miller which I have used (albeit only for an hour):
http://www.bhphotovideo.com/bnh/con...s&Q=&sku=327753&is=REG&addedTroughType=search
These are actully $900 - what you see is what you get.
They are very stiff, go down crazy low (you don't need to bother with a hihat), but lack pimp feet and a spreader - so they are slow to set up... also they don't bear as much weight.
Any opinions from owners or renters of these sticks?
_a
_a
