Aaron Koolen
Hi all. New to Final Cut and just got my DVX a couple of days ago and need some advice; that is, how do I capture 25p footage and edit it correctly without screwing anything up?
There are the normal presets for PAL DV which are set up for 50i but I'm not sure that's what I use. My thinking is that the 25p on the DVX is stored as 50i, so if I just capture using regular 50i settings and edit on a 50i timeline (Using easy setup PAL DV) then I should be OK. Is this correct thinking?
If not, what's the best way to do it? Do I need to change the field order of the captured clips and the timeline?
Finally, once edited and I want to output to, say, DVD (PAL) do I need to do anything special? I'm thinking here it's just plain simple - just render out to PAL DVD format using Compressor.
Cheers
Aaron
BTW: I did Google and search here, but no luck, so if you have some threads already, it'd be great to see them.
Cheers
Aaron
