Flintstone
I want to make sure that all my productions are broadcast legal as far as audio levels goes. I've worked at a community cable company for a while, and I'd like to find out if this standard is really a standard.
When recording on, say a BetacamSP deck, the standard 1KHz tone, when adjusted properly, should read 0VU on the needles. This leaves about 3 to 5 db room for peaks before distorting. That's fine for the analog world.
However, I find it difficult to comprehend when going digital. From what I'm told, and from what I gather from Avid NLEs, 0dbVU is translated to -20dbFS (full scale) on the digital side. Which means that the standard 1KHz tone is actually -20db on the timeline. Avid's audio meters show this quite clearly, however, Final Cut and Premiere Pro don't.
This means that on average, my audio mixers on FCP and PPro should read about -20db, with peaks not exceeding –15, right? This seems like such a waste of bandwidth. If on a BetacamSP, there are about +6db overhead above 0VU before clipping, shouldn't the tone be -6dbFS? Mixing up things even more, PPro's default tone is set at -12db!
So what’s the real standard? What’s the proper way to work audio in PremierePro? At what levels are Hollywood DVDs mastered in?
