oneinfiniteloop said:It allows you to capture "richer audio", but the less distortion and static noise parts are more up to you than the preamp. Some pre's will cut that stuff out and help with filtration, but good mic techniques will help much more. Using the shortest, highest quality XLR cable, keeping your cables in good condition, and mic positioning and/or isolation will help a lot to get rid of those problems.
Mic pre's are indispensible tools, and can add huge production value to your work. They can help you craft a tone and sound that may be difficult to create later in post work.
ullanta said:I just want to clarify the issue for the record, for posterity...
Mic pre's don't allow you to capture richer, less-distorted, cleaner audio. They allow you to capture audio. Without a mic pre you don't get WORSE audio - you get none (well, technically, a tiny amount. But practically, none).
The answer above applies to differences between mic pres, and likely is comparing external mic pres against the internal mic pres of the camera. Certainly, you can improve on those.
Motivity Pictures said:I read what you said elsewhere about the "line level" and so the "line level" of the camera just voids out any external preamp. I think you are right on, I'm just trying to get it all straight in my head. I'm a visual learner. Is there anyway to over ride the internal mic preamp on the camera?
oneinfiniteloop said:Using the shortest, highest quality XLR cable,
stabwound said:It's been mentioned here that the longer the cable, the worse the quality.
I pooped my pants when I just read that... I ordered a 25 foot xlr cable from the Sound Room. I figured I needed the length for a mic boom.
How long is too long when it comes to xlr cables?
ullanta said:Don't get hung up on it, man! I'm not saying it's never a concern, but sometimes mic cable quality/length is given far more importance than their relative influence on sound. In a real-world situation, the only difference you'll get between a 25' and a 6" cable is convenience. The connectors (and quality of the cable construction) will definitely outweigh issues of cable length in the sub-50' range. In general, in live situations, 200 - 300 feet of cable can be fine, except for mics with really low output (like, say, ribbon mics). The issue of WHERE the cable is (i.e., if it's running right next to an AC power line for 10 feet) is more important. But if you're comparing a 6" cable to a 25' cable coiled in the same place... don't worry. Even in extemely quiet, low-RF studios, cable quality and differences in cable length < 100' are extremely minor. In a TYPICAL situation, they're pretty meaningless. Cable construction, connector quality, cable abuse are things to worry about a lot more - things that might cause cable failure or lack of good electrical contacts.
