SMuir,SMuir said:Probably the easiest way to handle this would be to get one headphone amp with multipe jacks and seperate volume controls, and have everyone plugged into the same amp. The amp would be fed by the camera's stereo line-out, and you would need a headphone extension for the boom-op.
The headphone amp would be seperate from your monitor, but would give you all the functionality of a built-in headphone amp.
ART (http://www.artproaudio.com/) makes a mains-powered headphone amps called the HeadAMP.
PSC has a rock-solid 4-output model that runs on a 9V battery: http://www.professionalsound.com/Catalog/hda.htm
We are running a s-video cable (that has 2 separate audio cables on the same line) to the monitor. The monitor does not have XLR connections. Your questions has brought a possible solution to mind. Could I run the 2 audio cables (attached to the s-video cable) to an adapter that would allow us to attach headphones (MDR-7506) so my script supervisor could listen during the shoot? My boom operator is on a small personal 1 headphone amp, so he is listening. He is often 20 or so feet away from the monitor, so it would cause more trouble to run an additional cable from him to the monitor (pinning him from one cable to the camera and one cable to the monitor). I like to keep the monitor far away during stabilized shots. My boom operator follows me around, we work well that way.SMuir said:Is the XLR feeding a built-in speaker on the monitor? if so, you could simply put a XLR Y-cable in-line to split the feed between the monitor and a headphone amp amp velcroed to the side of the screen. Just leave the amp and splitter attached when you pack up the monitor, and you're not plugging in any more cables than you were before. That's about the simplest solution I can think of without getting into wireless solutions (which would simplify the setup and cabling situation for a rather steep price). Taping the S-Video and XLR cables together will also simplify the setup proccess.
Another way to speed things up is to get a boom cable with a built-in headphone return for the boom-op. The "Boom Buddy" http://www.remoteaudio.com/boom.htm is one such cable, although anyone handy with a solderring iron could throw one together quickly enough.
Thankfully the s-video cable I am using has 2 audio lines at each end along with the s-vid connection. I am going to do some research on headphone amps to find something suitable. I don't know much about headphone amps.... any suggestions? I think I'll go with the great suggestion of using a headphone amp at the monitor, where multiple people can listen to the footage at the monitor.SMuir said:I suppose that you could build a custom cable that would split the 2 audio lines from the S-Video cable, allowing you to plug them directly into a headphone amp. I haven't done much tinkerring with S-Video cables, so I'm not certain how plausable this would be. Another option would be to run a second audio line beside the S-Video cable, taking the output from the camera's line-out and going into the script supervisor's headphone amp.
I once worked with a steadicam operator who had a handy little battery-powered A/V line transmitter that attached to the camera. The script supervisor simply tuned a portable TV to the appropriate channel, and plugged her headphones into the set. The quality wasn't great, but it got the job done. I believe it came from a security/surveilance supply store.
Comtek? I have started to hear this a lot recently. I have to admit I don't know anything on Comtek. I did a search on B&H and found items that will work with Comtek transmitters, but nothing on the actual Comtek units. I'll do some research. Thank you for the suggestion...ptalsky said:Actually, this set up sounds like it is made for wireless. A Comtek or similiar system would give you everything you're looking for (1 Tx, 3 Rx). Then you don't need to worry about wires all over the place and multiple headphone amps. I went wireless for all monitoring except for the mixer (me) a while ago, and I'm not looking back. I'm going to be testing a new set of wireless from ListenTech which are less expensive than Comtek (again, it may be a case of you get what you pay for...but they have fixed a couple of serious Comtek problems found on the lower priced models, like built-in frequency tuning and mono to stereo headphone conversion).
Phil
Wabbit I love your quote: Fast, Cheap, Good. Pick any two.wabbit said:I will be interested in hearing how those work out. I agree about the 9v but since I cant get almost 3 days of use out one 9v on a comtek I haven't been sweating that too much. Would be nice to be all or mostly AA. It is impressive the low voltage draw of our equipment these days.
If you put your comteks on ebay make sure to post the sale in here. I can never have enough of those darn things :happy: "Oh look the producers 8 year old daughter wants to hear what's going on, give her one too."
Cheers
