PunkMetalDrummer17
Carbonite Member
The opening shot of my movie calls for a wave to crash over the camera and then raise to over 20 feet in the air. Is there a mount of some kind that will allow me to mount to the housing to the crane?
Smart Alac said:Mate,
What housing are you using?..
If you look at my housing in the pic below, its very easy to mount onto anything almost. See that handle on the side? Well that attaches to 2 short 1/4inch bolts about 15mm long which are fixed into the base of the housing.
Surely your housing would have something like this?...
puredrifting said:How do you propose to clear all of the water drops off of the housing in front of the lens port once it breaks the surface? Or perhaps the wter drops on the lens wouldn't matter within the context of your script?
As you know, there are spinning lens setups for when you shoot in rain or spray but none of those would work coming out of water, mounted on an underwater housing.
Dan
Jarred Land said:your grip will mount you in less than 15 minutes.. all you need is a few superclamps and some hex mounts and your set.
