Near Obsessive Compulsive issue with colour on dual monitors.
Aviv
Well, my Primary Monitor is a Viewsonic. I have a Geforce 6800 card with dual video-out so up until today I was using an old CRT monitor.Today I got another LCD monitor by Samsung. Plugged in, everything works fine. I use the Nvidia control panel to select that all full screen video should be displayed on the second monitor, so if I open a video file in Windows Media Player I can watch it in either full or normal screen on my primary monitor, but it will automatically be sent in fullscreen to my secondary monitor.
The same thing applies with Premiere (but not After Effects, odd.)...All the video in either the Source or Program monitor will play in full screen (without the docks or panels, simple full screen video) on my second monitor. Everything was fine when I was using a CRT as my secondary monitor but now...
I just can't seem to get the colour on both monitors to match! If I movie Windows Media Player from one monitor to another, the colour looks the same however if it's playing in my Primary monitor and all the full screen video is sent to the secondary monitor, the colour on the secondary just looks a bit paler...Hard to explain, but there seems to be more contrast in the colours on the Primary monitor than the full screen secondary monitor.
If I'm watching my DV footage on my Primary monitor, it looks fine but on the secondary it just looks pale. For instance, there seems to be less dark colours in my face, less of a contrast. On my primary monitor, the contrast has that almost darkish film look to it, while on my secondary it just looks pale. I fiddled around with the brightness/contrast/colour settings on the second monitor, but to no avail.
Then I checked the colour tool in the Nviida Panel which I can use the adjust the colour of the full screen video. I fiddled about with the Digital Vibrance and the contrast of each primary colour and got it looking perfect for when I run a video in Windows Media Player. It'll look the same on both monitors, however as soon as I go into Premiere and import that video, it will look less vibrant than the Windows Media Player version and it will be totally blown out by the digital vibrance on the secondary monitor...Then I have to adjust the digital vibrance to match the video in Premiere, but as soon as I watch it in Windows Media Player, the difference in colour is back. It's a total vicous cycle. When using bars and tones in Premiere to try get the colour right, I can get them to match on both monitors by pretty much setting everything to default (Nvidia controls and the second monitor hardware controls) but as soon as I watch that video outside of Premiere, there is a difference in colour....It's slight, but it's annoying...I imagine that when editing on two monitors the colour really needs to be exact.
Does anyone have ideas on how to sort this out?
Also, a lesser question, but both my monitors are 4:3, even though the secondary has a smaller frame, so it looks less square than my primary. 720X576 video has small black bands on the top and the bottom, but another resolution (and everything else like my desktop wallpaper) like 352X288 will be displayed totally filling up the whole screen...There's no option on the monitor to stretch the image, only move it's posistion.
Any ideas at all...Mainly for the colour problem, because it's really bugging me.
it is very tricky or nearly impossible to do this.
i've always used two identical monitors because i hate it when not only the colors aren't exact but the brightness and even the height or aspect ratio is the slightest bit different. i find it distracting if both screens aren't the same.
you can read the manual and play around with the color temp settings but i think that will get you sort of close at best.
matthew
