I'm finishing a film shot on super16mm which has a lot of green screen work, because of how poorly lit the screen is I have needed to go through and Autotrace certain areas so that I can work with a mask and isolate the parts in the foreground that are keying out or just keying badly. This works fine except for the fact that After Effects seems to create a heap of keyframes that move around (i.e: they move around the roto path like they are in a freakin race) This is causing the edges of the mask to boil and warp as the roto points move around. Any suggestions? I've tried shrinking the mask through a simple choker and blurring it with a gaussian blur but I still get the same problem.
I am using Keylight to pull the keys, and the footage is Uncompressed 8 bit.
Cheers
Cheers
