best setting to show dvx footage on web
vocare
Hi all,
will appreciate if you can give some comments on this .
for fcp 5.1, what is the best codec to export the footage for web?
currently i am doing coporate and wedding video in singapore.
any recommendation for the codec for my web.
www.vocaremedia.com
vocare = call to
just another proud dvx user
An mpeg-4 file with the H.264 codec would probably be your best bet, but it requires the viewer to have Quicktime 7.
Thanks for your reply.
correct me if you think i am wrong.
mpeg 4 is a lousy quality and given H264 is a hdv format.
what about swenson 3 comparing with mpeg 4 ?
i have been using swenson 3 format all along .
and its work with pc as well.
I'm sorry, but I believe you are incorrect on both accounts. Mpeg4 is becoming a standard for video on the web, and I've never heard of H.264 being limited to HDV. I've had good results between the two.
On the other hand Sorenson does a decent job, but I've come to find that H.264 produces a smaller file size, and H.264 is fine for both Mac and pc, but QuickTime 7 is required for both. If you've been using Sorenson all along then why change? If you don't want to take my word for it, then do some experimenting with the both of them and see what you find out.
