Capturing footage but then it aborts. Please help.
Ralph nixon
I'm using my 100b to capture footage into fcp with advanced pulldown. It seems to work fine most of the time but then suddenly it stops and a window opens that says "Capture now was aborted due to break in cadence in the vfr/pulldown in the source stream." I try to pick it up again but it won't go past a certain point in the continous shot that it's capturing (its not stop and start points) when that window comes up again. What does it mean? What should I do?
Is it true that the 100b is a great camera but a crappy deck. I'd be better off with a cheap camcorder for a deck and then the break in cadence in vfr/pulldown wouldn't happen as much...or is that just a myth.
Thanks.
I've had the error before, but it would usually go back and capture the clip and rename it. I guess that's not working for you, so I would try doing a capture now on the clip and restripe with TC.
