Anthem78 Active member Apr 2, 2006 #22 Is there a website for the indiFOCUS? Or anywhere I can see some pictures?
Anthem78 Active member Apr 2, 2006 #23 And Chris, are you planning on making a follow focus? If so, let me know how it goes. And if you do build one, I'd be happy to beta test it with the 35 I just bought from you.
twocik23 Veteran Apr 2, 2006 #26 Hi guys here is something I've found, the only problem is that they're 190.00 each! http://www.globalspec.com/FeaturedP...AShaft_Series_Right_Angle_Gear_Drives/13039/0
snodart Veteran Apr 2, 2006 #27 Would be nice, but the bore diameter for the shart is 1.5". http://www.wcbranham.com/products2.cfm?prodCatID=29 That's a pretty thick shaft :shocked: Also, the high price probably has to do with the high RPM rating (1200).
twocik23 Veteran Apr 2, 2006 #28 I was looking at the smaller one to the left of it. I just can't believe it's $190.00!
snodart Veteran Apr 2, 2006 #29 Ah, I see what you are talking about. "Bore combinations range from 5/8”, ¾” to 1” diameter." That is still pretty big though.
