bhiga:
My question about best bossible export quality had to do with future film transfer.
By the way I did some chroma key tests and the results where just amazing ! The only thing it troubles me is if there is a way to select/key from lets say five red windows in aframe only the two of them. It seems that there is no such flexibility around but anyway this is something that it should be done with a more dedicated program. Its only that since it seems that EDIUS uderstands chroma surprizingly well I wish its there and I just don't know how to do it.
So, how much the trial version is limited ? Barry mentioned P2 exprot wich I to cant find, and I consider an issue the confusion about 720p 25p over 50p that was mentioned in an other thread. I beleive you tried to explain but I didn't uderstand what you meant. So, are Edius settings actually the export settings and it doesnt matter what footage you import as long as it is suported ? But what if I want to export in 720p25p ? Still confused...
And again, any one knows what are the proper settings if you have DVCPRO-HD 720p25p over50p or 1080i 25p over 50i meaning shooting PAL ? Is this the trial versions limitation or there not such thing in the original as well ? I want to remind that I had downloaded the previous trial version also that didnt have DVCPROHD 720p at the settings but the 720p footage I worked with worked just fine in an HDV timeline... so there was actually an export limitation in this case. What now ?
