First DVD ... and it is not going well
Mr. Hector
Ok I am new to this and I am obviously doing something wrong.
Exporting from Premiere
Video Summary:
Codec: MainConcept MPEG Video
Quality: 5.00 (high quality)
TV Standard: PAL
Aspect Ratio: 4:3
Frame Rate: 25 fps
Program Sequence: Progressive
Bitrate Encoding: VBR
Encoding Passes: Two
Target Bitrate (Mbps): 4.0000 (low quality)
Maximum Bitrate (Mbps): 7.0000 (high quality)
Minimum Bitrate (Mbps): 1.5000 (low quality)
M Frames: 3
N Frames: 12
Audio Summary:
Codec: PCM Audio
Sample Rate: 48 kHz
Multiplexer Summary:
Multiplexing Type: None
I end up with three files with the following extensions;
.m2v , .m2v.mcses and a .wav file
I write them to a DVD-R aparetly successfully but none of my dvd players do anything when presented with the disc.
Have I missed something ??
You need to import those files in a DVD authoring program such as DVD Studio Pro and build a DVD project. Afterwards, you will then get an AUDIO_TS and a VIDEO_TS folder that you will burn on a DVD-R.
Hope this helps.
Thanks Kandinsky
I thought authoring software was just for making a fancy front end with links to chapters ect.. I just want the film to autoplay.
I guess when I upgrade to Premiere Pro 2 (which includes basic dvd authoring) I will have it covered.
Mr. Hector said:
Thanks Kandinsky
On the export menu choose > Export to DVD.
In the OEM version I have, Export to DVD is replaced by Export To VAIO and the "Vaio Zone" should sort out the DVD authuring.
At first I wondered why SONY would bundle Adobe Premiere Standard Edition with their computers when they have their own product in both lite and pro flavours.
I think the answer is that they want to drive poeple nuts with Premiere to send them off looking for Vegas.
It worked for me, I downloaded a trail Version of Vegas last night to see why such a large proportion of this forum use it.
