Barry_Green said:Confirmed that Edius can capture 1080/60i and 720/60p DVCPRO-HD through live capture.
What is the secret - care to share your Edius/HVX settings
Barry_Green said:The key is to recognize that DVCPRO-HD in Canopus is not called DVCPRO-HD, it's called Canopus HD (NOT TO BE CONFUSED WITH THE CANOPUS HQ high-def codec!). So just plug the HVX in, go to the capture input settings and choose OHCI, then go to the settings and choose Canopus HD 1080/60i. Or Canopus HD 720/60p, etc.
Disappointing because I thought the demo allowed you to test all the features including DVCPro support ... and capturePascal_Parvex said:There's no such setting. And I suppose I know why, because to edit HD, apart from HDV, you need the dongle, as mentioned in another thread, otherwise HD won't be unlocked. So this demo is pointless for the HVX.
crashoverride said:Hey Guys.
I know i know. I'm new on the forum, but might be of some help 2 you. We have the Canopus Agency in Cape Town SA. As far as i know, the demo version is only SD & HDV Capeble. They have disabled the HD support in the trail. We have just installed the Broadcast version and i must say it ROCKS.
Had a little bit of an issue with the output via NX Card, but found out that it is only capable of outputing true HD via the NX Card. Keep on getting a message PCI Bus Busy Error. SP Card will sort out the component output though.
Will go and test the trail on my laptop again and give you more feedback.
bhiga said:@Andreas:
@stabwound:
Canopus HD is the DVCPRO HD compliant software codec.
A few questions:
You didn't have EDIUS installed previously, did you?
Are you in a Canopus HD project setting?
Does Canopus HD show up as a capture setting for Generic OHCI capture?
Wow - I really like this graemlin!!
:nads:
We need one of these for the Canopus forums... as a user avatar.
rogar-Evil(DBG):
Brandon
