Ed Kishel
There is a growing concern re: the use of 35mm adapters with the DVX. Many fear the weight and the length may put too much stress on the front plastic threads of the cameras lens. Swinging the camera around and smacking the adapter into something could potentialy break it off if not supported. This is primarily a concern for those of us using static adapters, like Letus, My35, or the DIY project we are currently working on in another thread. Many who are carefull need no support and will be fine without one. But some of us dont want to risk our DVX or the adapter we have paid so much for, or spent so much time in building.
The most cost effective solution is the affordible rail system built by Cavision. The RS15IIM retails for about $175 and can be found at EVS and B&H and directly from the manufacturer in Canada. Now Cavision does make a lens support adapter for the rails front mount, however it is not quite long enough to reach some projects.
I have built an accessory for RS15IIM that allows you to adapt your Cavision's front mount to support 35mm adapters. It not only takes the weight off the front threads, but also includes an optional velcro strap that hold the adapter in place, snugly agains the riser. This allows for much greater stability for the camera and adapter.
This setup will obviously not completely protect the DVX from a serious hit, as no support would. It is an stabilizing aid- and care should be taken in manuvering the camera with a long adapter hanging out front. My protoype is at work so I dont have the exact measurements with me, but on monday I can post numbers and materials and how I made these.
