If the used Sony above is too expensive, your only options are still lenses, which you won't be able to control the aperture on unless your adapter has electronic control. Which mount are you currently using? Or maybe there are some vintage zooms with an aperture ring, like from Nikon.
Every company has a 70-200mm...the famous Canon f/4 version is like $300 on eBay if you can adapt it.
https://www.bhphotovideo.com/c/product/183198-USA/canon_2578a002_ef_70_200mm_f_4l_usm.html
Anything after 200mm usually becomes a slow and variable super-zoom.
Those are super zooms in which case it doesn't matter too much which one you get as they are all fairly mediocre:
https://www.bhphotovideo.com/c/prod...mm|24-120mm,fct_zooms-primes_5903:zoom-lenses
However, the way I see it is like this:
If you're definitely going to compromise on having a lens with that kind of range (totally valid) then why not spend a tiny bit more and get Nikon's 18-300mm for that extra reach?
https://www.bhphotovideo.com/c/product/1045736-GREY/nikon_2216_af_s_dx_18_300mm_f_3_5_5_6g.html
I know there's a hefty difference between the $200 Tamron 18-200mm on that list and the $700 Nikon, but I think a little more happiness can be bought.
Thank you for your advices! I need a lens that starts somewhere around 20mm and ends on 200mm or so. I need a longer reach for shooting theatrical performances.
I see this Nikon is a DX lens. Is it ok to use it with S35 sensor?
Dougs advice to 'buy a video camera' has merit..
But 50-300 F3 12mm gh4 will be far more pretty to look at (in my opinion)
For that kind of shooting is shallow DoF desirable? And obviously you're not shooting 4K or LOG with an F3. So I'd say that the F3 is probably the wrong camera for the job. A camcorder with a fixed 12x or 17x servo zoom lens or the ability to mount a broadcast-quality 1/2" or 2/3" ENG lens would be a far better choice for theatrical performances. There are some great deals to be had on used HD cameras and lenses. You are never going to find a decent 10x lens for the F3 that doesn't cost a fortune and/or weigh several times more than the camera itself.
Doug, I'm using F3 with the amazing picture profiles from your "Mastering Sony PMW-F3" training course. And this is another reason why it is so hard for me to switch to any other camera
D
I would suggest that the F3 with the 50-300 ED will look amazing
So I would say..
1) get a video camera
or
2) do 2 cams one of which could certainly be an F3 and 50-300
Each solution is good.
