Been working hard on an important project and finished it. But now can't export it. Crashes. Weird thing is I can't even scroll the timeline back to the beginning because as soon as a certain part near the beginning even starts to appear on the screen Premiere will instantly vanish/close to the desktop without even an error message.
So I can't even put the workbar area over the entire project. Nor can I look to see exactly where it's having the problem. I'm guessing it's a transition I did on top of some footage that was up-ressed with Instant HD plugin but I can't tell for sure. Yesterday I was playing from the timeline all the way through with no crashes. Now I can't even scrub it.
I started a new sequence and important the old sequence into that one and tried to export and it crashed but gave an error at least.
It's like that part of the timeline can't even appear on screen or else.
I'm at a loss. I've never had this weird problem. I've had projects before where a certain part couldn't play or render without crashing so then you just delete or change that part but you can't even allow the timeline of this part to appear on screen to do anything or even see exactly where the problem is!
The project is 23 minutes long.
So I opened an older version of the project and now it crashes there too.
Using the oldest version of the project I have, if I scroll really fast as soon as I open the project I can get back to the start of the project. (If I'm not fast enough it crashes before I can get all the way back to the beginning.)
So I turned off all the eye balls on the video layers so no red render bars and no video showed up. When I get to about 3:44 on the screen from the left almost immediately Premiere crashed to desktop again, no warnings. That seems to be the magical spot where it crashes no matter what. Somewhere between 3:44 and 4:14
It worked yesterday. I just don't get it.
So I've got about 30 seconds of a project I can't even look at.
Win7 pro. Premiere CS6
