would the field of view change? I'm assuming the FOV get wider, so a 24mm would look more like a 16mm or something. Can I use the 5d3 to get a feel for the conversion?
The 24mm will look wider on the Ronin (presumably it's a full-frame lens) than on the C300.
You can get a feel for the conversion with the 5D3. The full-frame sensor sizes are most likely not EXACTLY the same but close enough to get a feel for it (conversion should land somewhere between 15.5mm-16.5mm).
