scorsesefan
Does anyone have any experience with the A7SIII? Does it significantly improve audio quality/noise floor? Does it have it's own preamps? Thanks
I own an older version the Sony XLR K1M adapter and it is excellent. I don't think a one time experience is a fair evaluation NorBro. I bought the K1M version because it allows me to locate the unit elsewhere than on top of the camera so I have mine placed off to the side on the cage. The flexibility and options of these units far surpasses any Beachtek unit which I also have used and still have one kicking around it a plastic tub somewhere. I would suggest you rent one for a shoot and see/hear for yourself. not having to deal with batteries and fewer cables sticking out of the side of the camera as well as input switching options etc. As I said I prefer the model I have which is the earlier/first one but I am sure that if anything the K3M is as good if not better.
Best of luck with your research. Still find it hard to accept NorBro's point of view based on a one day experience. I have been shooting and recording with it for three years on my A7iii's, A6000 and A6400. Never had any issues with sound quality or noise.Good microphones, and craft either on my part or the audio person working with me who usually records on a Zoom as a backup but we use camera sound in post.
As I said I have both and I have the Tascam 60D which was another under the camera audio device (PIA). So I look forward to reading about your choice and experience. But if you can spend a couple bucks and rent both rather than assuming. Cheers
My observations/experience with the A7SIIIs internal audio has been less than stellar although admittedly limited. I shot a man on the street with a VMP from about 3 feet away from the subject(s) and the audio sounded a bit thin and noisy to me. But that's on-camera mics for you. And the VMP (original) is pretty old tech now. But I also shot some sit downs with my Rode WGII (with their built in mics) and the audio going directly into the A7SIII sounded worse than the Rode's internal recordings to my ears. But it may be down to user error as my peaks on the street interview were at -4, -3 and around the same for the sit down. Also, I definitely should have used lavs on the sit downs. In any case my mindset on DSLR/mirrorless vs cinema camera pres is a bit antiquated I suppose. I still think of it in terms of 5D vs FS7/C100 and I'm sure that has changed...
@Abe, I'm not sure if there's any compression on the Rode units. For the internal recording there is a compressed and uncompressed mode and I just leave it on uncompressed... @ Norbro -- yeah I have to update my mini-shotgun. I didn't realized the VMP's native gain was so low...
if I had to guess, I'd guess that the Rode wgII is recording the same file on both sides of the transmission? because it's sending it digitally, so it probably digitizes the file and then send the same file that it's recording on the transmitter. but then it spits back out an audio signal from the receiver to the camera, right? so I guess there could be some additional noise introduced there...but I would expect it to come out in camera sounding pretty much just like it does on the transmitter file. but I don't know that much about audio
but yeah, sometimes I feel like my tascam dr-10L recordings sound richer than my Sennheiser G3 sound, which I attribute in part to the tascam recording the signal directly from a wired mic vs the sennheiser converting the signal to RF and then back to audio. of course, that's an RF transmission vs 2.4Ghz of the rode, totally different animals. and i don't have total confidence in the theory
