glenn chan
This is bothering me because the .tiffs on the CML site show that Redcode is very very transparency. For 99.99% of the image, the compression is visually lossless (even if you zoom in 200%). The same cannot be said about 4:2:2 Y'CbCr (with no other compression), Cineform (no offence), DV's 5:1 DCT compression (or DVCPRO HD, HDCAM).
This begs the questions:
-Am I (not) seeing things?
-How does Redcode achieve such results?
My methodology:
Superimpose the images in Photoshop.
Set composite mode to difference.
Use the levels adjustment layer, drag the right slider to the left.
Make a new layer
Hit alt crtl shift E to merge visible to new layer.
Use that layer to help guide you to where the artifacts are.
Disable the layer, just compare the uncompressed versus compressed versions.
Zoom in if necessary (although this doesn't necessarily count, since real world viewers can't zoom in).
To compare to other codecs, take the uncompressed TIFF and encode that with the other codecs. The comparison may be slightly unfair, since Redcode can optimize itself for Red images (RAW space; it also knows the sensor characteristics).
Nevertheless, the Redcode images look much better than some of the other compression schemes out there. 8:1~9:1 in other schemes may be roughly equivalent to Redcode's compression (by 8:1, I am referring to a 8-bit RGB original compared to the 8-bit RGB compressed version in these other codecs).
My methodology:
Make a new layer
