I am using a DVX100b to livestream softball games, I am using the AC adapter. Also I do not have a tape in the camera while streaming. After about an hour and a half of continues use the camera shuts off, but as soon as it does I turn it off and install a battery an it is good to go, but if I turn it off disconnect the AC adapter then reconnect it and turn the camera back on it still won't come on. So my question is, is there some kind of time limit that they can be hooked up to the AC adapter and is there a time limit before you can use the adapter again. When I got home about 4 hours after the shoot I hooked up the AC adapter again and it work fine.
