Jason Adams
Section Moderator
I am starting a new thread on this because this is a how to. There is another thread that was started on this asking if it could work. It was stated that the Lenovo S10 would not work as a p2 offload station. My continued tests have proven this to be incorrect and I did not want you to dig through 4 pages to find a set up guide.
This is as concise as I could remember it.
*OS - I am using the XP HOME that came pre installed. Other users have installed OS10, Vista and even WIN7 with some results but none have posted any good results with the adapter. This set up guide uses the Out-of-the-box S10e OS.
Hardware:
Lenovo S10e - Radio Shack for 299.00.
Addonics express to card buss adapter - addonics for 59.99
I am also using E series P2 cards. - This is exciting because Addonics has had limited success with their adapters and E series cards, but this set up works.
Install.
1.) Install the p2 drivers from panasonic - make sure you have the latest ones
2.) Insert the adapter - DO NOT PUT THE P2 card in the adapter just yet. Winxp will detect and auto install the pci-pci bridge
3.) remove adapter from computer and reboot
NOTE - It is important to think of the p2 card and the adapter as a single card. Do not simply eject the p2 card and reinsert into the adapter, You need to always disconnect and reconnect the adapter and p2 card as one unit.
4.) After reboot insert the card (p2 and addonics together) then you need to manually install the drivers for the p2 card. Yes. After you have already installed the driver package from panasonic.
addonics has some screen cap videos to help with this.
vid 1
Vid 2
addonics does have good support. They remote controlled my desktop to do this. If you can not get it give them a call.
If done correctly the netbook will detect the card and display it as a drive that you can see with win Explorer or p2 viewer.
When you are finished with the card remove it (again adapter and p2 card as one) the drive will unmount and disappear from the WinExplorer.
QUIRKS: The next step is to make provision for one of the limitations of this adapter/hardware combo. The netbook WILL NOT AUTO MOUNT THE CARD WHEN IT IS RECONNECTED. This hardware is only somewhat hot swapable. Not to worry there is a work around that only adds 2 clicks to mount the card.
5.) Go to control panel (classic view) and right click on "add hardware" button. Select create shortcut. This will place a shortcut on the desktop. I renamed my shortcut "refresh p2" and even changed its Icon.
When you reinsert the card (again card and adapter) the led on the adapter will light but not mount. Go to our new desktop short cut and double click. The new hardware wizzard launches. Click next and immediatly the card will mount. YOU DO NOT NEED TO RUN THE WIZARD ALL THE WAY THROUGH. You can cancel the wizard after hitting next. The next button will refresh hardware changes and mount the card.
If you are familiar with device manager you can refresh from there to mount card.
To recap the workflow from now on is
1.) inserts card/adapter combo.
2.) rescan hardware or use our desktop shortcut work-around to mount card
3.) offload with winExplorer or P2 viewer
4.) remove card/adapter combo together when finished
5.) repeat with next card
Final Quirk:
I have noticed if you boot your machine with the adapter plugged in it disables the WIFI. I can only assume that system is expecting the pcmcia adapter to be an air card and makes provision for it by disabling WIFI. Removing adapter and rebooting will re-enable WIFI.
UPDATE - Thanks for the Question Barry. Sorry I was not clear on this. You can have WIFI and card at the same time. JUST DON'T BOOT THE MACHINE with card in the express slot. As long as you plug your card into the netbook after it has booted you can have WIFI and read P2 cards.
UPDATE - WINDOWS 7
Just wanted to let everyone know I just got this working on a WIN7. I set it up on WIN 7 Home Premium machine from my local Sam's Club.
WIN 7 actually works better because it does away with the rescan/remount task.
Just follow the directions as usual, but instead of creating a desktop shortcut to scan for hardware changes. Just scan once and the card will mount. Then go to the card in WIN EXPLORER right click and hit eject. If you eject the card in WIN 7 before you unplug it will auto mount when you plug it back it.
Summation:
For my money the cost/performance of this solution far outweighs the quirks. This is a portable battery powered P2 offload station for around 500 bucks.
Not to mention the netbook has an sd slot for scene files/metadata it makes it a great companion for p2 cameras.
Even with Software, OS, and recovery partition I have 135gigs available on the drive for p2 data.
They even make a 9 cell battery for this NETbook that will run the computer for nearly 8 hours. I don't know what that would translate to with heavy p2 offloading and hard drive spinning but I thought it was worth mentioning.
Jason
Hardware:
Install.
vid 1
Vid 2
Final Quirk:
UPDATE - WINDOWS 7
Summation:
Jason
