Hello!
I was on a wedding filming a performance when all of a sudden the audio goes from good to bad, you can hear the transition here: https://youtu.be/l0cTjZqc4Tw
Worth mentioning is that I was filming closely to huge drums for a good while, some times the audio went over the red point on the meters but mostly I had it almost dialed down all the way. All audio from this shoot after this point sounds like in the clip.
Now, when I got home and discovered this I did tests with the camera and everything works fine all of a sudden. As you may understand all of a sudden I got some trust issues with my cameras internal mic.
Do you guys have any clue what might have happened, could the drums have damaged something in the mic, and how should I test it to find out if this was some type of one time thing or if this is something that needs to be fixed.
Any help is really appreciated!
