Park Edwards
hey tester, why not start up a project over at sourceforge.net? is the code linux based? i also have the 1.2 firmware that allows 3rd party batteries. would that help any?
If you try to read carefully, you could find documents on used CPU core. Venus Engine is just marketing name for proprieraty LSI, same is true for any camera manufacturer.
Most other your theories are just plain wrong.
Please direct me to the pages in the MM103 user manual that describes the DSP processing performed by the chip on the sensor data, as well as the the block diagram that indicates the image data flow.
i will gladly donate to you for your efforts.
(even if nothing pans out).
Why do you need block diagrams and how they can help you (from my previous expirience with such things they won't much)?
Inside camera you have special LSI chip, normally with CPU and DSP. Usually they share same command set, but DSP have extensions and some low level parts are similar to FPGA.
LSI detail are closed for every major manufacturers.
Hello tester13
It's a service manual link: http://tsn.pasc.panasonic.com/viewing/ALL/DMC-GH1KPP/SVC/DSC0905029CE/index.html
It working on the Internet explorer (for my FireFox it don't work).
Tester13
www.henryolonga.net/mainboard.jpg
does this help?This is the main board and I will hunt for the audio one.
