DV Rack Free Upgrade #4 Now Available
OnLoMark
We have released Update #4 for DV Rack. The principal fix involves a bug in the way Type 2 clips were written that could cause them to be unusable with Matrox cards or in Adobe Premiere. It also incorporates a revamped activation scheme that, among other things, should avoid being prompted to activate because the network card has been moved or removed. If you have already activated DV Rack, you should not have to reactivate after installing this update.
This update applies only to the full version of DV Rack, not DV Rack Express. An update for that version of the program should be released shortly.
Update #4 is available both through the Check for Updates option in the Help Menu and for direct download here.
