I realize there probably are not a lot of Autodesk users here but some of us use 3ds Max or Maya as a significant component for production work.
You may not realize that Autodesk has made changes that affect your EULA and will prohibit you from activating your license in the near future should you need to switch machines, or upgrade your hardware which can break your license and require re-activation. The goal is to get people off perpetual licenses and onto subscription which you may view as a good thing or bad thing. If you have money invested in a perpetual license it would be wise to plan ahead as far as which version to stick with and hardware since you will not be able to change either soon.
More info can be found at www.aplocalas.com/ or you can dig through https://forums.autodesk.com/ where some users have discussed this
