Only progressive, why not interlaced?
When recording in SD format, i noticed that "normal recording" has more info on screening while squeeze and letterbox crop info from scene.
Why would you need to deinterlace 24p footage?The other guys know more about this than I do, however I have shot several projects with the dvx100b and upressed it to 720p using magic bullet frames to deinterlace, and instant hd to upres.
I shot most of them in 480i squeeze because they were multicamera shoots also using ag dvc60s which cannot shoot progressive. On single camera shoots I prefer 24p or 30p since the upressing seems to work a little better not having to deal with interlaced footage.
All that aside, I have usually managed good results at 720p.
If you have after effects, the high-quality upscale filter is pretty good.
You can also export to an image sequence and use Photoshop - make an automated action that upscales all the images in the folder, then import those as an image sequence to an HD timeline and re-render.
