If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
since people seem to be having successful results with the tiffen T1 filter; i'm wondering if i can use the 77mm size on my stock lens(EX1) in conjunction with a 35mm adapter such as the Letus Elite/Ultimate?
I do have both the 4x5.65" and 77mm versions of the T1 filter, and while normally using the former in my RR mattebox, I did test my Letus Elite with the screw-on on my EX1 lens.
The answer is : yes, it can be done. However, due to the increased distance to the Letus GG, I needed to set my EX1's zoom at some 88 (as compared to 77 without the screw-in filter), to avoid vignetting.
what about a varicross/star filter? i was about to make a thread asking about this..i was just about to buy a 77mm varicross filter and put it on my stock EX3 lens because it will be more affordable and alot easier to find. i cant find one for my mattebox(4x4).
so my question is.. will a varicross/star filter work if its on my EX3 lens behind my letus extrme? also will it work with the letus extreme on and my mattebox? my mattebxo has a UV filter on it..someone please respond!!
....The answer is : yes, it can be done. However, due to the increased distance to the Letus GG, I needed to set my EX1's zoom at some 88 (as compared to 77 without the screw-in filter), to avoid vignetting.
Piotr
thanks Piotr. i appreciate your response. Z88 from Z77 seems like a lot, but at least it works.
Comment
