If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Yeah, I initially searched EC but that didn't work too well (hundreds of combos), so then I searched EC with quotes around it ("EC") and one hit came back.
Fortunately they wrote it in the manual in quotes and not italics. (Although there may be an option to search just italics.)
I'm not really sure but my guess is the camera doesn't output 4K DCI in that certain mode and only UHD, so the 17:9 and 16:9 visual discrepancy seems like it's correct as it's notifying you with "EC" when they don't match (DCI vs. UHD...4096 × 2160 vs. 3840 × 2160), and disappears when the camera recording mode is back to UHD/16:9 to match the 16:9 output.
You're cropping some pixels when they don't match, so EC - Edge Cropping - makes sense.
By “doesn’t output 4K DCI” does that mean I am not recording in 4096x2160 even though the camera is set to 4096 and the VF display says 4096?
I understand that “EC” is telling me there is edge crop happening, but why is it alerting me of that? Or, put another way, why do I care? Is it telling me that the frame edges are different than what I see in the VF? If so, why not just grey-out the edge that isn’t being recorded?
And why 17x9? Why would anything be in 17x9 and not 16x9?
I need to learn more, obviously. The video engineers don’t make it easy. “Let’s give them two types of 4K, neither of which will actually be 4K. And there won’t ever be any actual 4K.” Yeah, thanks gents.
I don't know how it works in the FX9, but most cameras on the market only output UHD.
So when you are recording DCI 4K in some of these cameras which offer it and also want to output a 4K image to an external monitor, your only choice for the output is UHD (for most).
It seems like the FX9 - being the professional tool that it is - is telling you that you are recording DCI 4K but your output is UHD.
It doesn't affect your recording; it's just a courtesy note.
___
DCI 4K is 17x9 because it's slightly wider than traditional UHD which is 16x9.
If you're doing TV, you most likely want 16x9 and not 17x9. (But the world changes quickly so maybe that's a standard now for everyday work as well.)
And you want to know ("EC") that the edges are different just in case someone is seeing something different than what you are seeing in your VF (like for precise framing).
Btw, thank you for assisting me in my education, NB.
As soon as you think you know this stuff you realize you don’t. I’m starting to think it impossible to ever know it all. They keep throwing more stuff at us faster than one can keep up. I’m still trying to wrap my head around this “4K from 6K” thing. A “6K camera” that cannot record in 6K. Alrighty then. Makes perfect sense.
DCI can only be 17-9, its for theater release ..Digital Cinema Initiatives .. 16-9 is a TV format .. been around for ages .. the f5/55 had it .. and even the fs7.. I believe ..
It's oversampling...ARRI made the process famous in the ALEXA, which is why their HD/2K looked so good.
Now 10 years later, technology has caught up and you can get it in a $500 camera.
In short, you get better lower resolutions from higher resolutions.
But paper resolution isn't everything; C300 Mark II's 2K 4:4:4 looks better than its UHD.
Comment
