I had a shoot down in Orlando, FL the first week of August and I charged up my light battery and here it is September 8th and I still have 4 out of 5 lights lighting up on the battery....I used the light for about an hour or so when I was in Florida...Can't believe that thing still has a charge!
Announcement
Collapse
No announcement yet.
Kudos to Vidled!
Collapse
X
I am leaning towards grabbing a vidled, I want to shoot a scene on a train and figure I can use the incoming window for a key and then fill the shadows with the the vidled. (battery operate is appalling here) I guess this light should be daylight balanced, should I get the coolLED and use cto or get the dayLED. What circumstance would you ever want to use the coolLED in filmmaking given the color temp?
Jim
Comment
Originally posted by bosindyWhat circumstance would you ever want to use the coolLED in filmmaking given the color temp?
The coolLEDs are intentionally left un-geled, as they have their maximium output in their "virginal" state. You can effectively use them ungelled: 1) when it is your only light source; or 2) it is the dominant light source; and 3) for an interesting effect.
The notion that all lights in a scene HAVE to be 5600K (or all have to be 3200K) is somewhat absurd. There is a LOT to be said for using color in various shades for lighting a scene. Many movies use heavily colored lighting to achieve a certain effect. It is because of this reason why we now include 9 gels with each light; inlcuding some Gaslight Green, and some 1/4 CTB. Place some 1/4 CTB on the coolLED for an even stronger "blue", cold feel.
To light your particular scene you should be fine with a coolLED with gel. Keep in mind though, that if there is FULL sun coming in through the window, you might get more fill light from a simple reflector/white foamboard, than from a 6W LED light.
Cheers
Comment
Comment
