Hi All,
Today I received my Dedolight DLED10-D (daylight only version).
Very quick initial testing has left me very impressed. Colour tint is very neutral to camera with no noticeable green or magenta tints.
Shadow quality compares well to a DLH650. Maybe not quite as sharp as a DLH4 but to camera it is actually just as believable as sunlight. Have never seen a 300watt focusing LED (or fresnel attachment) with this type of shadow sharpness.
Brightness is exactly what I was hoping for - with the light 3.5 metres from the subject in full flood you are looking at 1/200, Iso400, F4.5. With the 150mm projection lens that bumps up to F5 at the same distance. At this distance you also get floor to ceiling coverage for full length shots.
The only negative I found is the brightness control knob. It has a limited movement of less than 360 degrees rotation and all 100 increments are squeezed into that space… 1 percent adjustments seem hard to dial in and it jumps between values. Hard to see any change with the light in that small percentage.. so practically speaking not a huge issue.
Happy to answer any questions and share a few pictures.
Comment
