If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Has anyone else experience Tota lights just failing. My friend and I both have lights that just failed for no reason. Naturally I tried replacing the bulb and power cords but it didn't help. Any insight would be appreciated.
I had a tota light fail once, and it was indeed very odd. I'm not a total dummy with electricity and electronics, but I couldn't find any failure in the "user accessable" sections of the light. It's been a long time since I've looked inside one, but I think mine had some sort of short inside one of the cast parts...meaning its was essentially unserviceable when contrast against replacing it.
I could be wrong though.
That being said, totas don't fail often in my experience, so perhaps you and your friend are simply unlucky.
I haven't had any problems with Tota's, but Lowell is a bit on the rinky dink side. If isn't the bulb, and it's not the cord, that leaves...the socket. I haven't checked, but you can probably order spare socket sides and swap them out yourself.
I'm great at spending hours trying to fix something that's cheap to replace. I do have a talent for taking anything *apart*.
Bob--maybe call Lowell and complain if the light is fairly new. i have no idea about their customer service, but I don't expect new stuff to break unless it's abused. Lowell has a 2 year warranty on lights, so maybe it's covered.
[quote author=xort link=board=lighting;num=1102015292;start=0#5 date=12/03/04 at 15:35:50]Send it in to them, they'll give you an estimate. I'll bet you will be VERY suprised at the cost, no matter the age.[/quote]
Comment
