I'm looking at getting a flexible lighting kit with the briteks. The wattage I was going to choose was the 1000/500, the 600/300 and a 200. This way a range of different power options. Problem is the ones with interchangeable wattages are not focuseable. Is this a severe limitation? would you get a good set of fixed wattage but focuseable lights like a 1000, 600 and 300 and use scrims, bounce etc to tune down the light output?
Announcement
Collapse
No announcement yet.
open faced lights- spot mode or not
Collapse
X
Re: open faced lights- spot mode or not
I personally found the focusability of the Britek's of mediocre use, don't expect too much from that feature. It's nothing like you would expect with a fresnel. I suppose every little bit helps though..Mike King - Sherwood, Oregon
Filmmaker, Runner, Chess fanatic, and Software Engineer
Comment
