Hello all. We used a DVX200 in the past to do this with a different external recorder. I have a client that will be using a Panasonic HC-X2000 for various breakout rooms, that's being paired with a Atomos Shogun Inferno. We're sending sound to the recorder for back-up, while we are capturing powerpoints on it as well. Does the 2000 have the capability to sync time (time of day, etc) with the Atomos? If anyone can provide some insight...that'd be awesome. This isn't exactly in my wheelhouse!
Announcement
Collapse
No announcement yet.
HC-X2000 Time Code To Atomos Shogun Inferno
Collapse
X
Time code should carry over sdi/hdmi, Should set the camera to Free Run, and also manually set the time code to time of day.
The shogun can also receive time code through the bnc connection on the back that's labeled "sync". Doesn't sound like it would be a good fit for your use case, but you can attach something like a Tentacle Sync to this port, then in the time code menu on the Shogun, you'd set it to LTC.
Comment
