Announcement
Collapse
No announcement yet.
GH1 Slow-Mo Strobingwha
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    I tried filming some slow motion footage with my GH1 but it came out awful, with the subject strobing and the subject had trailing image of itself.
    I set the GH1 to 720 and shudder speed 125. Does anyone know what's wrong?
    #2
    Likely user error/post error...which framerate? 60p? (You're listing the resolution which is irrelevant.)
    Also double-check if your shutter speed was actually 1/125 because in case it wasn't and it was below 1/60 (like 1/50) for 60p, you will have strobing and trailing. Needs to be 1/60 or above, preferably in the 180 to 90 angle range for most applications (like 1/125).
    Comment
      #3
      I thought the frame rate was automatically set in the 720p mode. Am I incorrect?
      Comment
        #4
        I haven't used the GH1 in like 15 years so if there is one framerate to choose from in 720p then you'd be correct, but I don't remember (and they never make cameras like that anymore).
        But if that's the case, check which framerate it is because it has to be at least 60p for smooth slow-motion otherwise slowing down 24p/30p won't work how you'd likely want it to.
        Comment
        Working...
        X
